TwinTurbo.NET: Nissan 300ZX forum - z will not start after replacing ECU harness
Subject z will not start after replacing ECU harness
Posted by ricerdaddy on September 19, 2008 at 9:41 PM
  This message has been viewed 146 times.
Message the engine crank but will not start. Pull the plug and ther no fuel.
the CAS and PTU wAS working correctly before I pulled the engine.
Checked the PTU plugs there in all the way in.
Checked CAS with is connect correctly. Seems like the injectors are not firing. The fuel pump is primeing. There is fuel in the fuel line.
Checked the ECU made sure it plugged in all the way and it is.
Checked the big plug that I have to depin to get the harness through the firewall. That is correct and connected also.
Also made sure all the grounding wire are connect.
Any help or idea would be appreciated?
